Elevation View Cuts Through End of Beam But It Doesn't Show as "Cut"
I'm currently working on a project in which a concrete structural framing member extends through a wall. The concrete beam extends past the face of the wall by 1'-0". However, when I add an Elevation View to the side of the wall that the beam cuts through, it shows the beam in the Projection Style (it doesn't actually show the beam as cut). The Elevation View is aligned 1/128" from the face of the wall, meaning that just under 1'-0" of beam end is extending past the cut plane of the elevation view. If I move then end of the beam 1" further past then face of the wall (end of beam is ~1'-1" past the face of the wall shown in the elevation view), the beam then shows as cut. I have a similar condition in which the reverse is true; i.e. the majority of the beam is "behind" the elevation view but less than 1'-0" extends through the cut plane of the view. (I'm hoping this makes sense).
I can cut in the same location with a section and the beam shows correctly as a Cut Pattern and Lineweight.
This seems like a glitch of some sort. Does an Elevation View that cuts through the final 1'-0" of a beam show the beam in the Projection Style instead of the Cut Style? Is there a reason for this? Is there a way to change this? Is this dictated by the Structural Framing Member or the Elevation View Properties?
Any help or insight is appreciated.
Replies (17)
RDAOU
@Anonymous
Why the 1/128"???? cant you pull it back further away from the wall?!! like 1/10"
That distance doesn't seem to have any bearing on the result. I tried it from as close as practical (1/128" from the face of the wall) to the very end of the beam (1'-0" from the face of the wall) with the result being the same. The beam still shows as a surface instead of a cut. If I move it the other direction (into the wall) by as little, the beam shows correctly cut. Just the last foot of the beam depicts this way apparently when cut by an elevation.
RDAOU
Can u post a screen shot of the layout and where u r placing the elevation cut line...
Sent from my iPad
I've attached a plan view and the elevation view here. The red line represents where the cut occurs (at the wall face). There is 1'-0" of the 60"x100" Beam that extends through the wall. In the attached "Elevation of Beam," you can see that the beam is shown in the projection style while the adjacent beam is shown in the cut style. Let me know if this clarifies my issue at all.
martinTstewart_Adsk
Autodesk Support
Autodesk Support
I see you’re new to the forum with just a few posts. So welcome aboard!
  • What version of Revit, and what build exactly, are you using?
  • Was the model started in this Revit version or in an earlier one and upgraded?
  • What operating system are you running?
  • For this elevation view, double-check the Graphic Display Options to make sure you don’t inadvertently have Depth Cueing on (and that all the settings are as intended).
  • Try making another elevation view. Do you get different results?
  • Try a section view. How does that look?
  • Does turning Hardware Acceleration off make a difference?
  • Does your video card driver need updating?
If none of that helps, can you post the actual .rvt file here?
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Martin Stewart
AEC Support Specialist
Thanks for the welcome.
I'm using Revit 2017 Build 17.0.501.0 on Windows 10 Pro 64-bit.
The model was started in 2017 and is a Structural Model.
I'm unsure about the Depth Cueing but it seems to only apply to Architectural and Coordination Views (This is a structural discipline view).
I tried the section in the same area and it showed up correctly. A new elevation at the same or similar location shows the same thing.
I checked updates (Found one and updated it) and unchecked the hardware acceleration but nothing changed.
My guess is that this is a property of beams and elevation views but I wondered if anyone else could confirm that.
martinTstewart_Adsk
Autodesk Support
Autodesk Support
This may be a matter of where the elevation clip plane is being located.
Where that plane is placed in relation to that beam will make the difference in appearance:
I've demonstrated this in a short Screencast video with audio: Elevation view clip plane
Martin Stewart
I appreciate your response, Martin. However, looking at my second post where I attached images of the condition, the Clip Plane is denoted by the Red line which cuts through the beam.
I've attached a Screencast showing how the beam behaves as I move the Clip Plane.
martinTstewart_Adsk
Autodesk Support
Autodesk Support
There was no Screencast link.
Martin Stewart
I get this same problem with columns, my elevation view is cutting thru the column however the elevation view shows the column in projection.
Did you manage to get a fix for this?
I didn't yet. Martin was running it up the chain to see if there was something bigger that needed to be done. My gut tells me that this is an inadvertent glitch or perhaps Revit treating Concrete Beams similarly to Steel Beams in some way.
Stay tuned.
Do you have a couple pictures or a Screencast of your issue to post here? They may be related or it may be a different issue.
Kris
GatisM
Hi!
I found this topic on autodesk knowledge network link. I think you have the same problem.
How I understand there is the only one solution, you must UNCUT wall and beam geometry. Let me explain how I see this problem. If you have model two walls Revit get autojoining elements, and if they are of the same category you can't see joined lines at all. But if you are joining two different categories than you get these projection lines. I think it must be improved in next releases of Revit.
If helped mark as a solution, and will be glad for kudos!
Gatis
martinTstewart_Adsk
Autodesk Support
Autodesk Support
The article Gatis linked pertains to this:  Section views: Unexpected line weight on common edges where beam is joined with compound floor
Any additional workaround may be to use line work to clean up the  display as desired.
And this could be a good Revit Ideas suggestion, to modify this functionality.
Martin Stewart
jweber-
Rather than starting a new topic to cover this, is there any way I could bring this topic back to life and ask if anyone has found a solution?
I, like the OP, have created some (interior) elevations, and with structural beams as timbers to a sloped ceiling, and when the elevation cut plane is parallel with the ridge and within 1' of the ridge, it will not show the beams as "cut". It even shows the beams behind the cut plane as if they are somehow projecting themselves into the cut plane and being shown in elevation view (not being cut). I can post photos if it would help explain the situation further. Thanks.
GatisM
Not actually understand, but did you tryed change visbility trough : view preoperties, extents, Far Clipping and try to change options.
I never received a solution to this. This was done in a previous version of Revit but I have not noticed if the problem was solved in the newer releases. As I mentioned above though, it appeared to have something to do with the behavior of the Structural Framing default parameters. i.e. "if cut is in the last 12" of a beam, show as projection surface." It's a strange default that doesn't usually create an issue except for in very specific instances.
My solution was to add a filled region for this particular view. Let me know if you find some other, better solution.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
