Editing the steel connections 2019 database
I recently learned that all the data from steel connections in Revit lie in some databases found at \program data\Autodesk\Revit Connections 2019.
As I started using the built-in connections in Revit, I realized that I have little control over tagging bolts, because when I call the diameter parameter I get values such as 30.00mm, instead of just 30, as I want.
Even though its not a huge problem, I wondered if there was a way to change, which led me to the .mdf files found on the above mentioned directory.
My question is:could I edit those .mdf files in sql server management studio to change the value from 30.00mm to 30?
shefypattambi
Hi @Anonymous ,
I believe you can modify the database in advance steel and place that database again in the revit connection folder.
@shefypattambi , thank you so much! that worked great!
I find I can actually edit the Revit Connections database directly, by using the Advance Steel Management Tools -> Table Editor -> Open Database, which then I browse to the Revit Connections database...this is awesome!
One step further: would it be possible to edit the database so that I could get the hole diameter property out of some holes? Eg. I want to tag my bolts so that for an M24 bolt I get the parameter of the hole which would be 27mm. I know this is information is in those databases, but would I be able to show some other parameter rather than those stock parameters that bolts have?
Once again, thanks a lot!
shefypattambi
"I find I can actually edit the Revit Connections database directly, by using the Advance Steel Management Tools -> Table Editor -> Open Database, which then I browse to the Revit Connections database...this is awesome!"
Cool.Thanks for that info Smiley Happy
Regarding to your question ; it is possible to tag the hole separately in Revit. I am attaching the inbuilt hole tag for revit 2019.2 for your reference.
@shefypattambi
Thank you! I was using a parametric connection and I wasn't able to tab through to the holes, but now I can.
Unfortunalety I wanted to create a tag with something like: 18 holes diam.27 for bolts M24. This tag would have to get parameters from both the bolt element and the hole element. This won't be possible, right?
michael_coviello
Autodesk Support
Autodesk Support
Hello @Anonymous
I'm glad you found a method of getting the units to not show in the tag.
I recommend you to visit the Revit Idea Station to post an enhancement to this functionality.
I urge you to mention the business impact that this missing functionality has as it can increase the chances of the functionality being integrated in the future.
You can also vote on ideas others have posted, so be sure to let us know if an idea you see there is important to you.
If this helps to answer your question, Please 'Accept' this post for others to find this information more easily. Thank you.
Michael C
Technical Support Specialist
What's New in Revit 2023 | Autodesk University | Revit Blog
rbarreiros.eng
Thanks @michael_coviello , I will check the Revit Idea Center!
