Edit Rebar Constraints Mode
andrei.oancea
andrei.oancea
In the last months I needed to work a lot with the Edit Constraint Mode.
It seems that if I enter the Edit Constraint Mode in one View (let's say in a 3D View), Start edit mode in 3D view then activate 2nd section view.jpg
then switch to another View (let's say a section) where I am able to see better my element. Revit exists the Edit Constraints mode .
The result is that it jump out of the Edit Mode and luckily it still keeps the rebar object to be edited still selected, so I only need to hit the Edit Constraints button once again. --> it is a reflex which I got while editing constraints.
This is something what a Revit user does not expect while working in Revit and what in Edit Sketch mode for a rebar is supported.
farzanbayat74
Hi @andrei.oancea
If you have any ideas for Revit to make it more user friendly, you can post it on Revit Ideas forum. thanks.
https://forums.autodesk.com/t5/revit-ideas/idb-p/302
jay_colcombe
Strange as i recall some additional functionality feature on one of the recent Revit releases to allow quick switching between views during the process in the same Tool/Function?
Would definitely raise it an a wish item in the Idea Community
Jay Colcombe
Autodesk Certified Instructor
