DYNAMO- WORk
Hello that such, because a couple of days giving Tin;
With much help from the Forum and tutorials videos seen.
began to learn and lose the fear to the DYNAMO, got the Bill of materials of structures. (Structural Column Schedule) in Excel is that this can be through the export of reports etc. But in the same way, I wanted to try it with the DYNAMO.
Later found out me that you could modify that table (Structural Column Schedule) from EXCEL and change the values and that they are updated in REVIT.
Working with the DYNAMO and seeing various tutorials I understood how you can generate a REVIT to Excel table modify the Excel and with the help of le DYNAMO take Excel modifications and loaded to the REVIT.
Unfortunately I came across a problem:
Warning: Element.SetParameterByName operation failed.
The parameter is read-only.
The columns I want to modify are:
Column Location Mark
Base Level
Top Level
Base Offset
Top Offset
Type
and in these columns in which get me those notes.
SERA that definitely are blocked or can I do something
help please
P.s. attached files that you work with are a basis not i wanted to put a lot of data to not delay.
P.s. 2 : Please try uploading the file Dynarmo but not let me, if someone occupy let me know and sent it.
