DYNAMO- WORk
DYNAMO- WORk
DYNAMO- WORk
Hello that such, because a couple of days giving Tin;
With much help from the Forum and tutorials videos seen.
began to learn and lose the fear to the DYNAMO, got the Bill of materials of structures. (Structural Column Schedule) in Excel is that this can be through the export of reports etc. But in the same way, I wanted to try it with the DYNAMO.
Later found out me that you could modify that table (Structural Column Schedule) from EXCEL and change the values and that they are updated in REVIT.
Working with the DYNAMO and seeing various tutorials I understood how you can generate a REVIT to Excel table modify the Excel and with the help of le DYNAMO take Excel modifications and loaded to the REVIT.
Unfortunately I came across a problem:
 Warning: Element.SetParameterByName operation failed.
The parameter is read-only.
The columns I want to modify are:
Column Location Mark
Base Level
Top Level
Base Offset
Top Offset
Type
and in these columns in which get me those notes.
SERA that definitely are blocked or can I do something
help please
P.s. attached files that you work with are a basis not i wanted to put a lot of data to not delay.
P.s. 2 : Please try uploading the file Dynarmo but not let me, if someone occupy let me know and sent it.
L.Maas
In general. If you ca not do it in the Revit User Interface there is a big chance you can not do it with programming (Dynamo).
You already have a clue wat is the issue "The parameter is read-only."
If you look at one of the columns in the GUI
You see that the parameter "Column Location Mark" is greyed out, meaning read-only.
You can not change it in the user interface so you can not change it by Dynamo.
How would you change the Column Location Mark in Revit User Interface? By moving the column to different location.
In Dynamo this would mean you would have to select the column(s) and move it to different location
Louis
Please mention Revit version, especially when uploading Revit files.
A_MAQ
Big like for @L.Maas , this the whole story i would not say anything more
Autodesk Expert Elite
