dynamo script help - coordinates
CLMSJ
Message 1 of 26
CLMSJ
Hi, could anyone pls help me with updating my coordinate script? its supposed to take coordinates from the survey point but it doesnt seem to be anymore. I think its taking coords from the origin? any help would be much appreciated. Many thanks in advance
Replies (25)
Message 21 of 26
will_young
Not sure what the issue is, it works on the model you sent initially on my machine. If you post the model you have there I can check again and see if I can work out why it's not matching.
Message 22 of 26
CLMSJ
ye im confused aswell seen as its working your end. file attached
Message 23 of 26
will_young
Very strange.. I tested again and it works straight away, I'm not changing anything other than entering the XYZ parameter names and setting coordinate base to survey point.
I plotted the coordinates it's setting on your machine below and the piles are off by the same amount as if it's missing a step somehow.
Message 24 of 26
CLMSJ
i will try creating a new project and creating new piles to test it on. just have to finsih a job first. will let you know how i get on. Really appreciate the help
Message 25 of 26
CLMSJ
Just created a new revit file, added four piles and run the script again, seems to work fine on the first go without moving the survey file from its original origin point.
when i move the survey point and re run the script, it worked this time! dunno why it didnt the other day.
now i moved the piles around and re run the script and it works perfect!
Many thanks for your help on this will, very much appreciated 🙂
Message 26 of 26
will_young
Great news, glad to help.
