Announcements
Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Dwg Layers
5 REPLIES 5
hvcprecast
295 Views, 5 Replies
Dwg Layers
Hi how are you ,
I just have one question , on exporting from Revit to DWG ,
I import 100,s of precast wall panels to dwg but the views in the sheet have dimensions on them and it is being imported as a Layer A-ANNO-DIMS,
How can disable or make so that this layer does not import to dwg.
Thank you in advance
Please email to me at hvcprecast@saktel.net
John
5 REPLIES 5
in reply to: hvcprecast
What you see is what you get.  Temporary turn off dimensions prior to export, or duplicate the view without dimensions and export that view.
metehanhanedan
Hey,
you can specify which layers to be imported at the Import CAD window. Select Layers/Levels option as Specify and press open.
New window will pop up. You can select or deselect the layers to be imported.
hvcprecast
Thank you very much guys. this is nice to know. I didn't know that But I'm still a little bit stuck with what I want to do.. I have 200 shop drawings. to export on every drawing. or project. And I would have to do that. on every sheet or export. I can export all 200 shop drawings at once. but will be a lot of work doing this with each one , I just thought there might be a way to do this on the import side
John
hmunsell
 View Templates (VT) are used to help control view visibility settings, among other things.  Make a View Template (or several) to control the views appearance for your different needs.
  • Make one VT with the dimensions turned On
  • Make one with them Off
  • apply them as needed.
VT's can be applied to a bunch of views at once from the properties window by highlighting them in the project browser. They can also be applied from a View Schedule.
Howard Munsell
hvcprecast
Thanks guys every bit of info gave me tips to accomplish what i wanted to do , So what i did is i went in there a created a 2nd view but without dimensions .and then i exported these views
John
