Duplicate Views as dependent ...with different scale
ivtay
Message 1 of 27
ivtay
For Revt 2013 Building Design Suite
Can we duplicate view as dependent with option to set to a different scale from main view?
These dependent views are cropped to show part of main view, set to a larger scale and onto sheets.
Currently, an having to switch between scales for plottings of different sheets, causings tags to be displaced from preferred position ...
Or am I not doing it right...?
Thank you!
Ivy
Replies (26)
Message 2 of 27
AJA14
To do that, you need to first duplicate the main view (not as a dependant). This will be your working view. and then create your scaled views as dependant from this view. Your original view remains with the original scale.
Remember to use matchlines and view references.
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
Message 3 of 27
ivtay
Thank you Ali,
However, the tags do not follow. I will need to tag the duplicated view ...that wld be double work.
Is it possible to have changes/additions plus tags reflect on the duplicate views (with different scale) as well?
regards,
ivy
Message 4 of 27
CoreyDaun
Are you tagging the same elements on both the large scale and the enlarged plans? Wouldn't that be redundant work anyway if this weren't done in Revit? There is no way to have a Dependent View at a different scale than its Parent View, so at the very least, you can copy/paste the annotations from one View to the other. You will have to make a lot of adjustments to these annotations, though.
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Message 5 of 27
AJA14
Hi again,
If you originally duplicated with detailing, and then created dependant views from the dummy plan (which is a duplicate with detailing), that should solve the annotations' issue.
If I misunderstood you question, please let me know.
CADastrophe makes a good point in that you shouldn't tag both because that would be redundant.
Ali Al-Hammoud
Message 6 of 27
ivtay
Thank you. I do understand what you are saying. Thing is, we need to prepare part plan/views of a drawing sheet (often in larger scale) for issuance. It is common practice in our office, so avoid frequent full size sheet issuance.
Thank you.
regards,
ivy
Message 7 of 27
I am surprised that this issue which I am having to find work-arounds for still exists in Revit 2014!
I too need different scale, dependent views. My workaround is to do the following everytime I send drawings to the client:
1) delete old partial view (enlarged view)
2) re-duplicate the original view , recrop it, rep-place it on sheet, rename, etc...  [and I need to do this about 16 times]
Very frustrating!
** The other (quicker?) method is to create an annotation group for each plan and have the duplicate (enlarged plans) contain a copy of the annotation group.
Also frustrating, as dimensions/spot elevations/tags can still not be added to annotation groups. So they still need to be copy+pasted for each enlarged plan. And there is the constant extra step of editing the annotation block each time you edit/add/remove annotation from each plan.
Is it just me, or does it seem like Autodesk does not communicate with the end users of their software while they are making revisions.
I have used Revit almost daily for years and still each version has things that seem so easy to fix.
Message 8 of 27
Hi..
I have question related to this issue too! I want to make drawing sheets for the same title but different scales. So, should I make titles in working plan with difference scales, for example" 1ST FLOOR PLAN, SCALE 1:100 , then duplicate 1ST FLOOR PLAN SCALE 1:200" ??
So if I have this 30 sheets, I should then duplicate it all. Then the Tags as well ~> This is so frustating!!
Can we just arrange it on Sheets?
Please help. Tks
Message 9 of 27
It's not only You. We have 2016, and things are the same. Not having a dependent view in a different scale increas worktime.
I would say some more, but it's not appropriate to use some words...
regards
Bartek
Message 10 of 27
Have you tried doing it as Callout on the main view? not sure about limitations that come with that, however its an alternative to having multiple views with different scales some dependent some not.
Message 11 of 27
ivtay
Yes! Callout with tags will work on Views of links (set "by link view) and allows change of scale, although we cannot moved the tags.
From your suggestion, I searched further and found this:
http://help.autodesk.com/view/RVT/2016/ENU/?caas=caas%2Fdiscussion%2Ft5%2FRevit-MEP-Forum%2FCallout-...
Merging the the above processes, we can then manage all part views for issuance in a separate Revit file (with link of main model).
It is a better work around then exporting to DWF / DWG and preparing it in AutoCAD.
Thank you!
Message 12 of 27
You seem to have missed to point entirely, which is this: There is a lot of information (tags, annotations, linework, etc.) that we would like to have in the original view transfer also to a dependent view. I'm running across this issue right now as I am attempting to show schematic site design on two sheets, at separate scales.
It's quite ridiculous to have to do all of the same work twice just because you can't create a dependent view at a different scale. All of the work-around options here only satisfy the situation if you are setting up the views and don't anticipate having to move or edit anything.
Message 13 of 27
You also missed a point that annotation on different scales can be vastly different appearance/arrangement wise.  A piece of text on 1:10 scale can be tiny but it can cover the entire view if you change the view's scale to 1:1000.  A stack of leader notes spaced nicely on a 1:50 view will become an overlapping mess when you change the view's scale to 1:200.
I don't even want to say that repeating information is commonly regarded as a bad practice in the industry.
Message 14 of 27
Yes that is absolutely true, and something I'm sure we would all like to see Autodesk address as well. (Having text/tags/annotations scale with the rest of the drawing)
Message 15 of 27
* I just wanted to add that Revit2019 still does not fix this issue. (Dependent views still are linked to the same scale as the original views). Oh well. We have to work with what we are given. 😕
[Hey AutoDesk, want to improve your software a lot? Perhaps hire or interview one of us who have used your software for many decades and have used it on hundreds of projects. We can tell you what improvements would make your software even better.]
Message 16 of 27
Still no workaround as per 2019/2020
Message 17 of 27
SteveKStafford
This feature was introduced to respond to specific user requests, primarily from the MEP community at the time. They expressed a desire to work in an overall plan view of the building while using their normal designing scale which usually does not fit on a sheet. They wanted to then carve up that work into partial plans and retain the annotation work done in the overall view. The goal being able to transition back and forth from modelling and documentation tasks without having to bounce from view to view too.
As such, without any extra overrides in play, the only thing that can be different in any child (dependent) view is its crop boundary. It was introduced to support the Matchline feature as well, they arrived at the same time.
The notion of using varying scales between dependent and parent views is recurring but the logic that applies to them falls apart quickly in the implementation of a solution. Most of them have been expressed in this thread and many others over the years. Generally, if a user says the solution is obvious or easy...it isn't.
The notion of annotation changing size as scale changes is also fundamentally at odds with Revit's beliefs. Annotation is designed to maintain size because graphics standards for ages require it. When annotation shrinks or expands inappropriately, like in other CAD application, you end up with pretty bad looking work. Revit was designed to eliminate that. The implication of this "client/boss" and "standards" driven requirements is unique views and annotation are required when specific things must disregard such standards.
Steve Stafford
Message 18 of 27
Workaround is Duplicate with Details, then change Scale.
Message 19 of 27
Base12
Just use a 24-foot wide by 12-foot high sheet of paper and put the entire project on it at the same scale, sheesh! What? That's not practical?
Message 20 of 27
tony.bouwmeesterB3AKQ
Observer
Observer
Still no solution in 2021. It is a pity that Revit programmers prioritise purist programming over real-work user needs. The only solution I can see is to use 2D groups copied into multiple views as a way of capturing drafting elements across multiple scales.
