Dragging Grid 3D drag point for Radius grids
simmonsEDP9W
simmonsEDP9W
Dragging 3D grid portion (up) in Elevation. (so the grids don’t show up on plan).
Easy to do with orthogonal grids. A little more challenging with grids on a Radius.
In order to drag the 3d portion of a grid, you must have a view perpendicular to that grid.
Since each grid below is on a Radius – I had to cut an individual section perpendicular to each grid
to modify the 3D grid drag. (I have 30 more grids to do).
What doesn’t work, Elevation, Framing elevation, & scopebox.
Notice below, I’ve cut a section and dragged the 3D grid drag – so that it doesn’t show up In plan.
Cutting a section for each grid is tedious.
 Any suggestions for a faster fix??  What I’m doing is working and I believe is current best practice. (just slow).
Hiding in view or putting them on a different workset is not best practice. I would consider that answer a
band-aid.
Autodesk - Best answer - click on multiple grids and allow the 3D portion of that grid to be offset from a particular level - in Properties Dialogue Box.
simmonsEDP9W
Thanks for any suggestions.!!
David
simmonsEDP9W
Started a test project.....looks like the scopebox is the way to go.
i thought that was the answer...but it doesn't seem to be working in the project i need it to work in.
Thanks!
