Dragging Grid 3D drag point for Radius grids
simmonsEDP9W
138 Vistas
2 Respuestas
Mensaje 1 de 3
simmonsEDP9W
Dragging 3D grid portion (up) in Elevation. (so the grids don’t show up on plan).
Easy to do with orthogonal grids. A little more challenging with grids on a Radius.
In order to drag the 3d portion of a grid, you must have a view perpendicular to that grid.
Since each grid below is on a Radius – I had to cut an individual section perpendicular to each grid
to modify the 3D grid drag. (I have 30 more grids to do).
What doesn’t work, Elevation, Framing elevation, & scopebox.
Notice below, I’ve cut a section and dragged the 3D grid drag – so that it doesn’t show up In plan.
Cutting a section for each grid is tedious.
 Any suggestions for a faster fix??  What I’m doing is working and I believe is current best practice. (just slow).
Hiding in view or putting them on a different workset is not best practice. I would consider that answer a
band-aid.
Autodesk - Best answer - click on multiple grids and allow the 3D portion of that grid to be offset from a particular level - in Properties Dialogue Box.
0 Me gusta
Soluciones aceptadas (1)
139 Vistas
2 Respuestas
  • Grids
Respuestas (2)
Mensaje 2 de 3
simmonsEDP9W
Thanks for any suggestions.!!
David
0 Me gusta
Mensaje 3 de 3
simmonsEDP9W
Solución aceptada
Started a test project.....looks like the scopebox is the way to go.
i thought that was the answer...but it doesn't seem to be working in the project i need it to work in.
Thanks!
0 Me gusta
