Drag elements on selection doesn't work in multi-monitor window
pieter.zeenaeme
pieter.zeenaeme
The 'drag elements on selection' function works fine in normal mode but when using multi-monitor windows the 'drag elements' function isn't working anymore. (Revit v2019.2)
See video.
Lance.Coffey
Autodesk Support
Autodesk Support
Thank you for the question.
I've tried reproducing the steps from your video (in a new project), but I am not seeing similar results (i.e. Drag elements on selection is working without issue).
Can you confirm if this is occurring with a new project?
Additionally, are you seeing this occurring on multiple systems or just the one (so far)?
Lance Coffey
Technical Support Specialist
pieter.zeenaeme
@Lance.Coffey
Hi Lance.
I only have the problem on my own system. Good tip.
So I think i'll have to look for a solution by changing settings or mouse :-).
Thanks for all.
