Double Fields and Rebar Model doesn't match to Rebar Schedule
vgmontalban
vgmontalban
Hi All,
I have this Double Fields and Rebar Model doesn't match to Rebar Schedule
See attached Image for Reference
ovidiu_paunescu
Hi @vgmontalban
You are probably using shapes defined using shared parameters that have different definitions, but same name.
This happens for example, for imperial and metric rebar shapes loaded into the same project.
For that shape that is not reporting the correct length, you should look at how the shape family is defined. Dimensions and assigned parameters.
Ovidiu Paunescu, M.Sc. Str. Eng.
Sr. Product Owner | Autodesk Revit
vgmontalban
@ovidiu_paunescu  Sir is it Possible for me to delete the Rebar Shapes and how? I found out that I have two/duplicate rebar shapes? (see attached image file), in rebar shapes I have this 00 and M_00 Shapes and so on.
vgmontalban
I think that's what happen to my project i have this Imperial and Metric Rebar Shapes? is there any way I can unload or remove the other one? i want to remove the imperial rebar shapes and retain the metric.
Thank you
ovidiu_paunescu
Yes, you can do that.
You can just delete them from the project browser.
You need to replace the shape for the bars that are currently using shapes that you want to delete.
To do that you can use a schedule to identify the bars, or delete shapes one at a time and see which elements depend on those. You will see an error message saying that some elements will be deleted.
vgmontalban
Thank you sir @ovidiu_paunescu
