- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
The new steel families in AISC 14.1 are great but not complete. Double angles are missing for one, not sure if other types are missing as well. Problem is the properties of the families in the AISC folder are different then the families not in that folder which makes a MTO complicated because of the different parameters utilized. i.e. in the AISC folder families use a "Nominal Weight" parameter and the families outside that folder use "W" as a "dummy" parameter for unit weight, which required conversion to multiply by the length to get total weight. The AISC folder is a great improvement, but it is not complete!!!!
Is there a timeframe when all families will be included in the AISC folder.??
