Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
different Web on truss family
3 REPLIES 3
TomasoCardia
941 Views, 3 Replies
Hi to all,
I need to know if it could be possible to create a family of truss with different web inside (like the image)
Thank you all!
3 REPLIES 3
in reply to: TomasoCardia
You can set one member type as default then unpon and change the others to different types. Do if for one truss and copy it to create others.
TomasoCardia
in reply to: ToanDN
thank you! It seems a great solution..
Do you know How can I get this type of truss? I mean the and bottom chord are made by two lines.. I don't have nothing similar schemes on my library (I have always with the bottom line as a one line)
I am not a structural engineer so I am not sure the there is a prebuilt truss family like that. Anyhow, if you cannot find ine, simply open a similar trus, split the bottom chord and constrain them as needed.
