- Mute
- Permalink
- Report
Started at a new company in the beginning of January. I'm running into an issue where when inserting standard details from the detail item library (Revit project) The lengths of the bolts reset back to the default values. Various other families do this as well, weld symbol and breaklines, but the steel objects remain and about 90% of the detail items.
There's no shared parameters involved, for the most part, the families are OOTB Revit with custom line styles applied.
In the screenshot below, the original detail is on the right, a new project, with the detail "Insert from File".
Both the source and 'project1' files have had the same 'bolt' family inserted from the server to verify they're looking at the same definitions of parts.
(This one has the whole sheet brought in, but even by just the detail it does the same thing.)
