Design change from overlap to couplers
paradonk
paradonk
I work with Revit 2017 and I have a model from customer, but all rebar reinforcement were detailed as overlap jointed. Is it possible to automatic change from overlap jointed to coupler?
ovidiu_paunescu
Hello @paradonk
There is no automatic way to do that.
If the bars are overlapped and shifted, one with respect to the other (so that there is no clashing), adding a coupler will move the second selected bar so that it aligns to the first selected bar.
The following tolerance applies when placing a coupler between two bars:
More info here
Ovidiu Paunescu, M.Sc. Str. Eng.
Sr. Product Owner | Autodesk Revit
