Cutting an element with the host based family which is not the host of family
Message 1 of 8
Hi All,
I have a floor based family used as a thickening for the floor / base slab and I  am having another floor below the host floor as a base blinding for the main floor.
I have created one floor based family hosted to the main floor and I wanted to cut blinding floor with that family.
Any help is much appreciated.
Thanks.
Accepted solutions (3)
Replies (7)
Message 2 of 8
kunalwadhera
Hi my fellow revit expert 😉
I suppose you can use the 'JOIN' tool instead of 'CUT' tool, and doing it will give you what you desire.
Kudos
Kunal 🙂
Message 3 of 8
Hi thanks for the post.
Can you please explain it in detail. I tried to use it in the model but not working
Message 4 of 8
kunalwadhera
Hi
I created a sample for you which you can find in below ref images.
I have taken a Floor based generic family template for 'CONCRETE THICKENING' family and made the profile as required.
Simply loaded it into my project.
and made 'Join' with my blinding.
Please refer below images for more clarification.
ref img 1 - Showing 'CONCRETE THICKENING' family, Slab & blinding same as your ref img in which the blinding is going through the Thickening.
ref img 2 - Showing the 'Join' command, which you will use to make a join between blinding and concrete thickening.
ref img 3 - Showing the Blinding being cut where the concrete thickening family is coming after the use of 'Join' command.
Hope this solves your problem.
Message 5 of 8
dferreira-blackwell
Use join tool, Select tool -->select your cutting floor family--> select binding floor. You will get your results.
Message 6 of 8
kunalwadhera
Hi there
You just repeated what i already said.
Kindly read the above replies and please do share some new ideas if u like.
Message 7 of 8
dferreira-blackwell
my bad, I did not read your reply.
Message 8 of 8
Thanks man..it helped..!
