Cut profile line style in detail view
Good morning from New Zealand,
When a profile of a (say modeled strip foundation) is altered with cut profile in a call out detail, how is the line style of the cut profile set, I assume it is inheriting the line style of the "object style" of the modeled object, is it possible to alter this style of each of the sketch lines to have some say, invisible and others dashed and/or solid? The line work override changes the whole profile and there is no selectable option in "override graphics in view" with r-click.
regards
Malcolm
Hi !!
If I understood what your problem is I think these screenshots can help you.
In the modify tab of the ribbon you have the tools "Lines" that permits you to click on every line in the view to change it representation.
You can define some new type of lines in the manage tab of the ribbon.
I don't believe the linework tool works with Cut Profile. Cut Profile always reflects the Cut line definition of the category under VG.
Thanks, i thought as much but hoped there may have been a work around out there.
Cheers
Hi ,
Unfortunately I tried that and it you can't pick the cut profile lines in the normal view only the original lines and in edit sketch of the profile the modify line style is grayed out., But thanks any way.
Regards
