CUT LENGTH AND LENGTH
Message 1 of 13
what is difference between cut length and length in Revit structural framing
thanks
 vikas
Replies (12)
Message 2 of 13
jeroen_vanmassenhove
As described in this article: https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
"Length is the measurement of the beam's representation in Coarse detail display. Cut Length is the measurement of the physical geometry in Medium and Fine display."
Kind regards
Message 3 of 13
 Dear  Mr.Jeroen
thanks for replying, but  not understood its concept behind cut length and length, what is the use of it
regards
Kind regards
 vikas
Message 4 of 13
which length represents for material take-off consideration as the length
of the concete beam
Message 5 of 13
As stated in that article, the lenght is a representation, the cut lenght is the physical geometry (the 'real' lenght). So the Cut Lenght is the one you need.
Kind regards
Message 6 of 13
M.elmekawy
the length is the distance from start and end points of the framing element
cut length is the clear distance between the supports of the framing element
cut length is always less than the length of the framing element
If my answer helped you please mark as a solution, this helps others to find answers quickly........
________________________________________
Mahmoud Elmekawy
Structural Engineer / Instructor / ACP (Revit Structure & Architecture)
Message 7 of 13
THANKS  Smiley Happy
Message 8 of 13
Smiley Happy thanks for graphical explanation
Message 9 of 13
Cut length is the actual length of the framing member, but if I build a parametric family (ie angle wall) from L-angle framing members and share them in the family then place in a project, Revit only reports the framing member length in a schedule not the cut length which is basically useless.
Any ideas how to get the cut length to report?
Message 10 of 13
jafaartdx5
That is very helpful thank you very much sir
Message 11 of 13
RSomppi
The only reason I am responding is to correct this as it was marked as the solution and is wrong.
As noted in the other solution, the length is the one line representation of the element, center to center.
The cut length is the actual physical length and can be longer than the length. Example: a beam resting on top of two columns will have a cut length longer than the length.
Message 12 of 13
James_Tran9P22V
Community Visitor
Community Visitor
This is WRONG. Cut length can be longer than length. It all depends on the cut angle. If you cut an RHS / SHS at 45 degree then definitely the cut length will be longer than length
Put it simple
Length is the distance between end points in 2D, think about structural analysis where you only model a beam element as line element.
Cut lengh is the actual length you need to buy to make that member (i,e distant between perpendicular lines of 2 furthest ends). So for the fabricator, they are only interested in cut length because that is the length they need to purchase from mill.
Below is an example of cut length > length
Message 13 of 13
RSomppi
Isn't that what I said in the post right above yours?
