Cut beam (end visible)
I have cut the beams to a reference plane, but as you can see the end is still visible. Anyone have a solution for me? See picture.
shefypattambi
Hi @Anonymous
Try to make your beam "end extension" as 0 from the instance property.
So when I try to set the "end extension" to 0, Revit tells me "Elements do not intersect." and then I can't cut geometry. I also tried to make a "Opening by Face" at the end of the beam with the same result.
ennujozlagam
did you use beam system to create beam layout? if yes just click then you can edit the perimeter or post your file so we can check. thanks
