What is the "right way on a column (front/back) and how to best apply that to a connection. I can se som x´s on de modify connection dialog.
How to think about front/back on connections in "Edit type dialog"?
The problem shows when I change a baseplate and put a custom top plate w custom steel attached.
Thanks.
// Vilhelm
Hi @VillHamp
Could you attach part of a model, a screencast of whats happening or some screenshots so we can see what is happening?
Rob Merriman, AEC Technical Lead, Graitec
Hi thanks for replying,
Base and top plate does not sync in direction, so when modifying connections it would be nice to know what to look for. connections should point in the same direction, whiteout 3 times of trying with errors=).
Take care,
Ville
