Creating irrgular column shape family
muhammedkhairy
Message 1 of 10
muhammedkhairy
I have a telephone shape Column
I'm trying to create a family on Revit, but I can't find a way to adjust the diagonal width.
I draw a reference line at end of C dimension as I want it to move when I change C value which can't be done with reference plan as I tried a lot. but when I created I a second reference line and associate the distance between the two reference lines to bwall, when I change the value of bwall the the shape width scaled but not to the desired value.
Is there any way to create this shape.
thanks for your help
Replies (9)
Message 2 of 10
Can you use structural walls?
Message 3 of 10
muhammedkhairy
I think the structural analysis behavior will be different
Message 4 of 10
Ahmed_Muharram
can you attach the AutoCAD file
Ahmed Heteba, PMP, bsi, B.Sc, AEE, ACI, ACP
Senior BIM Manager @ EllisDon
Message 5 of 10
muhammedkhairy
Thanks for your response. Here is the AutoCAD file
Message 6 of 10
Ahmed_Muharram
check this family on REVIT 2024
and you can tell me which parameters you need to be changing "you have to make some formulas to be fully parameteric"
Message 7 of 10
Ahmed_Muharram
Message 8 of 10
muhammedkhairy
Thank you, I'm sorry I have Revit 2022.1 and can't open the attached file, Is there a way to open it?
Message 9 of 10
Ahmed_Muharram
unfortunate no, I will make on 21 today and send you
Message 10 of 10
Ahmed_Muharram
attached on REVIT 2021
