Create sections automatically on grids
m_steenhartABA4E
m_steenhartABA4E
We want to automatically create sections per grid line, so grid line A has it's own section, grid line B has it's own section etc... How can this be done (easily)? Mostly likely via a Dynamo script?
ctm_mka
yes it should be possible in Dynamo, here's a quick workflow:
  • collect all the grids you need
  • retrieve their definition curve (bewared multi segment grids, extra steps are needed!)
  • get the start & end points of those curves.
  • create sections using those points.
rosie_lucas1
Hello @m_steenhartABA4E,
Did the information provided by @ctm_mka help you and answer your question?
If yes, please click on the "Accept Solution" button on the post(s) that solved your problem. This will assist other community users in finding and benefiting from this information.
If not, please do not hesitate to give an update in this thread so all community members receive an update on the progression of your question, and can suggest next steps that may be helpful for you to achieve what you're looking for.
All the best,
Rosie | Community Manager
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Let us know how we did on Trustpilot.
Rosie
ewano
Hi @m_steenhartABA4E
Definitely possible and something I had already make a Dynamo graph for a long time ago.
Hit me up on the Dynamo forum via DM (@Ewan_Opie) or a post once you have tried a few things for yourself, as that is always the best way to learn in Dynamo.
There will be a couple of considerations in the user facing side within Revit as well.
Cheers,
Ewan
Autodesk ITF 2018-2020 / Senior Project Drafter / Technical & Computational Modelling Specialist / Dynamo Enthusiast
