Create custom Steel Structure with Unknown shape of connected element error
vuongbui.nuce
vuongbui.nuce
i try to Create custom Steel Structure  profile, then i loaded in my project but if i using steel tab like bolt, anchor, connection, miter... i dont know why when i custom they dont working but if i create like rec. square, I shape, ... from library it works. thanks
robertwmerriman1
Hi @vuongbui.nuce
For the steel tools to work on a family they need to be either structural framing or structural column. You also have to ensure the family is setup as described in the following link - https://help.autodesk.com/view/RVT/2023/ENU/?guid=GUID-6244E741-5D14-4DAD-AE25-5069F71B69F3
Make sure your dimensions are setup exactly as the following page - https://help.autodesk.com/view/RVT/2023/ENU/?guid=GUID-5C94C05B-3463-4492-B97D-BC9E622147B7
You also need to ensure you have the detailing dimensions setup in the family - https://help.autodesk.com/view/RVT/2023/ENU/?guid=GUID-F987AEF5-8426-439C-BBB3-F2F53F0B956B
Rob Merriman, AEC Technical Lead, Graitec
vuongbui.nuce
hi @robertwmerriman1  i read carefully your help. i try make a new customSection like image shortcap above. But it doesn't working with Steel Tool Revit also. My description error in 3 image above. Can you explain for me why i can't use steel tool. thanks!
robertwmerriman1
Hi @vuongbui.nuce
If you look at your custom section the shape is "Not defined" in the links I sent through the steel tab functions will only work when the shape is defined properly - https://help.autodesk.com/view/RVT/2023/ENU/?guid=GUID-6244E741-5D14-4DAD-AE25-5069F71B69F3
Ahmed_Muharram
check this thread might be helpful https://forums.autodesk.com/t5/revit-structure-forum/profiles-rotate-when-placing-bolt-connection/td...
Ahmed Heteba, PMP, bsi, B.Sc, AEE, ACI, ACP
Senior BIM Manager @ EllisDon
