Just wanted to report that every time I try to select an option in de properties drop-down for "Title on Sheet" the program crashes. Notice this only happens when I'm using multi-line text in the drop-down. By multi-line I mean: Typing and then using CTRL+Enter to achieve the break.
Using Revit 2019.2 / OS Windows 10 pro 64bit
Hello @gaweinls ,
Thank you for reporting this issue. When Revit crashes, are you presented with a form to send feedback to Autodesk?
This is known as a CER form. If this happens, What is the CER #?
Does this crash happen in any project or a specific project? I tried reproducing this but could not, This could be due to many factors including addins. How to disable add-ins for Revit
If you have addins, does this crash happen when they are disabled?
I look forward to your reply!
Hello @gaweinls I am checking back to ask if you need assistance with this problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
