copy reinforcement error
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
1) I have create some foundation beams and I also create the reinforcement for these beams. When I copy these beams even the elements the reinforcement is changing automatic (some bars became shorter or longer then original). This is wrong because the beams are identically.
I hope is about some settings, because if is really that you can't copy an element with reinforcement in safe conditions (without the program change the length of bars) , the program isn't reliable. I have to mention that the reinforcement exceed the concrete.
2) Also if I define an element with reinforcement and that reinforcement exceed the concrete (It will be anchored in other element), the program automatic change the host of stirrups that are outside the concrete. This isn’t what I want ( for example the reinforcement cage of columns –part anchored in foundation must belongs to foundation not to columns)
