copy rebars set aligned from bottom to top in the same host
REDO10
Message 1 of 12
REDO10
Hi All,
why I get an offset between top and bottom rebar sets and I entred same parameters (cover, lenght, spacing) and same constraints in the same host ? (check picture bellow)
is there a way to copy rebars set from bottom to top without offset?
I trayed to copy rebars set from bottom to top with same aligned place function but Revit tel me that rebars have no host and constraints are changed
Thanks.
Replies (11)
Message 2 of 12
ovidiu_paunescu
Hi @REDO10
You should use the same edge for the distribution path, for both the top and bottom sets.
This will ensure that the bars are overlapped.
Ovidiu Paunescu, M.Sc. Str. Eng.
Sr. Product Owner | Autodesk Revit
Message 3 of 12
ovidiu_paunescu
You can also use create similar, to start the placement of a free form rebar set with the same properties (layout, hooks, workshop instructions) as the existing one.
Message 4 of 12
REDO10
Hi @ovidiu_paunescu
I tried create similar function but always I have an offset!!?
And I selected same edge to define path distribution for both sets as you said but I get same result!!
Thanks.
Message 5 of 12
shefypattambi
Hi @REDO10
Have you tried to use the align [AL] command?
Message 6 of 12
REDO10
Hi @shefypattambi
I dont know how to use align command
Have you an example to illustrate that?
Message 7 of 12
shefypattambi
Could you please share a portion of your project where you have this
problem.? I will test it and let you know.
Message 8 of 12
REDO10
Hi @shefypattambi , @ovidiu_paunescu
Please check my attached REVIT file bellow
Notice That I use REVIT v.2021
Thanks.
Message 9 of 12
ovidiu_paunescu
Hi @REDO10
The bottom rebar's distribution path end is constrained to that end face, while the top rebar's distribution path end is constrained to the cover. That small difference and the maximum spacing is causing the sets to not be aligned.
You can edit the constraints of the bottom bar and click the constraint to cover control to switch,
OR, if the bottom one is correct, you can edit the top one "to face".
Also, I would not recommend any type of movement of the free form bars without the host, as this would make those bars lose the constraints.
Message 10 of 12
shefypattambi
Hi @REDO10 ,
It is better to follow the solution provided by ovidiu.paunescu . If you find it difficult then you can follow this method and later set the Rebar constraint if required.
Message 11 of 12
REDO10
Hi @ovidiu_paunescu
Thanks a lot for your reply
Indeed, I did not notice the difference between the rebars path constraints of the two faces.
Thanks.
Message 12 of 12
REDO10
Hi @shefypattambi
Thanks for your reply
Finally Ovidiu gived me a solution for my problem.
