Connections in LSF
Connections in LSF
acostaU6S2R
Connections in LSF
acostaU6S2R
Is it possible to design connection between a Steel beam and a LSF purlin?
robertwmerriman1
Hi @acostaU6S2R
The Purlin family needs to be created as a structural framing family with the shape dimensions as shown in the link below, if the family is created exactly as these shapes the connections wont work properly.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2020/EN...
Once you have the correct families in the project there is a whole category of cold rolled and purlin connections
Rob Merriman, Technical Specialist / Principal Structural Designer, OLG
acostaU6S2R
@robertwmerriman1Thanks a lot.
