Im having trouble automating connections in Revit.
The normal connections do not work, I get this as an error
<libraryFilePath info="Library file path">No library file or it doesn't exist</libraryFilePath>
I have adjusted the path via File > Options > File Locations > Places > path too metric steel libraries
but I still receive below message.
file:///C:/Users/o.calkoen/AppData/Roaming/Autodesk/Revit/Autodesk%20Revit%202024/Connection%20Autom...
I have also added custom connections for HEA100 and HEA120 beams to colomn but these also do not work. I can only add these manually by selecting the colomn and beam and then under the steel tab clicking connection. I am then able to choose my custom connection from the list of types.
I want to be able to automate this for larger projects
