Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Concrete column and concrete wall will not join in Revit 2024
8 REPLIES 8
Message 1 of 9
Goodjp1
603 Views, 8 Replies
Hello Folks,
  I have started a new project in Revit 2024 recently. When i place a concrete column next to a concrete wall they will not join. They are the same material. Does anyone else have this issue in 2024?
Jim
8 REPLIES 8
Message 2 of 9
ennujozlagam
in reply to: Goodjp1
edit your column family, untick automatically joins geometry to walls, change your current column with the new one?
Message 3 of 9
jay_colcombe
So straight OOTB using a Revit Structural Template
Structure Tab > Wall > I placed a Basic Wall Generic - 300mm
Structure Tab > Column > I placed a Concrete-Rectangular-Column 300 x 450mm
As you can see they are automatically joined
you can use - Modify Tab > Geometry Panel> Join > Switch Join Order to determine the connection between the objects
Making them the Same Material then cleans up common edges/lines  no matter what Join Order chosen
Jay Colcombe
Autodesk Certified Instructor
Message 4 of 9
Goodjp1
Thanks everyone!! What i found out was it does not show in detail level course view, but when i changed the detail level to medium the wall and column showed as joined!! Revit 2022 you could have it in course level and it would show joined.
Message 5 of 9
jay_colcombe
If you look at the images above they are all in Coarse Detail Level so it still works in this Detail View as expected but glad you have a solution!
Jay Colcombe
Message 6 of 9
Goodjp1
in reply to: jay_colcombe
That is interesting. I wonder if it's because we just loaded our families from Revit 2022? What do you think?
Jim
Message 7 of 9
JoshuamRivera
I believe the fix is to review your Detail View options. Instead of coarse use medium or fine instead.
Best wishes
Joshuam - Structural BIM VDC Design Director
Feel free to Like this post if you find it to be helpful.
Click on the ACCEPT SOLUTION button if your question was answered.
Message 8 of 9
jay_colcombe
Possibly, it could be some under the hood settings forcing the differences?
Usually Autodesk probably do a Dynamo script to upgrade their families unless reported broke 😉
Jay Colcombe
Message 9 of 9
If you review at the images above they are in Course Level of Detail so for clarity their is some View Override (Vv/VG) level of detail setting of Filter (doubt that)
Jay Colcombe
