Complex Rebar Shapes
takundat1
takundat1
Good day guys, I hope you're well. I wanted to ask how one can model the rebar displayed in the detail below (Picture 1). It's a detail of rebar at the base of the circular tank shown in the picture (Picture 2).
RDAOU
Hi there @takundat1
No pictures were attached
takundat1
Hello @RDAOU, I do apologise for not posting the pictures. I don't know what happened because i swear i attached them. Anyway, I've reposted them below.
RDAOU
@takundat1
Did you try to sketch them or try use multi-planer rebars and it didn"t work?
All looks kinda standard and nothing that complex...Which part specifically did not work?
takundat1
@RDAOU, isn't it because of the circular geometry of the tank, the rebar has to be free form?
RDAOU
@takundat1
Sorry I thought you were referring to the the Multiple bend in the column
For the circular ring wall foundation, you can use Aligned distribution...select all the concrete faces that the bar needs to follow and then a distribution path (the two edges that make a full circle) The distance will be measured at the distribution path.
Check also this video tutorial from Autodesk it covers almost all the elements you have in that model
Revit 2019.1: Free Form Rebar - Aligned Distribution - YouTube
