Changing the base level of structural framing
shubham_shri
shubham_shri
I am not able to change the base level of structural framing element
Shubham Shrivastava
Autodesk Certified Professional for Revit Architecture
If you find my post helpful, feel free to give Kudos
teodorb
Could you send also a picture with an elevation? Do you have just one level in your model?
Bogdan Teodorescu
Product Owner
shubham_shri
here it is
Shubham Shrivastava
teodorb
For concrete beams you would need to do the following:
- Select the beam
- Click the Edit Workplane button on the Options Bar.
- The Rehost option will require you to first set the view's workplane
- Choose a different level or other workplane.
Hope it helps.
Bogdan Teodorescu
Product Owner
shubham_shri
Yes, It did change the level
but i have to do that every element separately
is there any other alternative way ??
Shubham Shrivastava
Cut and paste aligned to another level?
shubham_shri
Yeah, i did like that only
but i just wanted to know if the base level of a framing can be changed from properties pallet
Shubham Shrivastava
