Changing section view direction as default in Assembly
shuaib009
Message 1 of 23
shuaib009
Have couple of queries in Assembly.
1. section#3 comes as default views towards downside. How I can set this to view toward upwards.
2. When I insert views into sheets all the views shows up the section marks. However I do not need this in every views. I want to show in only one view! Every time I will go to view & hide the element.
When we have lot of drawings to prepare, both above becomes time consuming.
Thanks.
Replies (22)
Message 2 of 23
ennujozlagam
you can create a view template hide those sections and apply to the views you don't want them to see. thanks
Message 3 of 23
shuaib009
Thanks for your response. I tried, But it doesn't work in that way.
I wish that worked that way.
Message 4 of 23
ennujozlagam
can share you file so we can check? thanks
Message 5 of 23
mms7DUKZ
Sure. here it is.
thank you so much.
Message 6 of 23
ennujozlagam
you already hide those section line here? what is the issue? thanks
Message 7 of 23
shuaib009
yes, I hide it manually, so far.
Try to prepare a new assembly, you will get all above problems, which I mentioned.
Hope you will come up with a solution.  thanks.
Message 8 of 23
shuaib009
Message 9 of 23
shuaib009
yes, I hide it manually.
Try to prepare a new assembly, you will get all above problems, which I mentioned. Thank you.
Message 10 of 23
ennujozlagam
check put this and see if helps. thanks
Message 11 of 23
shuaib009
Thanks heaps for solving problem #2 @ennujozlagam .
Problem #1 is due to revit programing mistake. If you are changing vertical section orientation it works, But same thing doesn't work for horizontal section. you can check in the project I sent.
Message 12 of 23
ennujozlagam
are you referring the section line to be upward? just click the section line and the arrow will appear just click those arrow to change direction of your section line. thanks
Message 13 of 23
shuaib009
Thanks for your response. Yes we can switch the direction of Section easily as shown by you.
The main problem is section do not get updated after changing direction the horizontal section mark. however vertical section works fine.
Hope you got my point. thanks.
Message 14 of 23
ennujozlagam
Check here if this is what you meant? Thanks
Message 15 of 23
shuaib009
Sorry. No, This is not what I meant.
When you change orientation of vertical section plane, this should be reflected in sectional view as shown in 2 below images.
note below, that section direction changed ! However  this do not happen in the case of Horizontal section.
Let me show you below.
Example of (Problem)Horizontal Section below:
Hope its clear for you now. Thanks your patience 🙂 .
Message 16 of 23
ennujozlagam
how about this? and try to install latest updates from autodesk and sometimes it fixes issues. thanks
Message 17 of 23
shuaib009
Dear Junne, Thanks for all your efforts. Kindly note that when you are changing the direction of section-3, in section view there is no change. Kindly see carefully, there no change in section-3. It should get flipped, like in the case of section view-4.
Yes, I will try to update my Revit. Hope it fixes the issue. Thanks heaps.
Message 18 of 23
ennujozlagam
it changes the view when i flip the section line. have you see the video? thanks
or try to show me in video on what you are trying to achieve?
or try to download the file i attached and try if still the same with your issues?
Message 19 of 23
shuaib009
see the below explanation.
hope you understood the problem.
Message 20 of 23
ennujozlagam
it should be the same  thickness/view because you are cutting a horizontal view section line and only flipping the section view? thanks
