Change Color of Revit Link
Message 1 of 23
Hi ,
Good morning everyone.
I was wondering if I could Change the color of the Arch Revit Model link to red ?
I was checking if CMU walls are aligned with Arch model and got blinded by
staring at so many lines clustered together.
Thanks for your help.
Much Appreciated.
Replies (22)
Message 2 of 23
Looks like you may have 2 options here:
  1. If you are using worksets you can change the color of the workset that the link is on to red
  2. Select the link, right click, go to "override graphics in view", then the option that says "By Element" and change color here to red.
Message 3 of 23
VG > Revit Links tab > Display Settings = Custom
Basics tab = Custom
Model Category = expand all, change all to Red.
Message 4 of 23
A_MAQ
If you need to change the color of any category , you can go to VV
Autodesk Expert Elite
Message 5 of 23
A_MAQ
For changing the whole color , you can check  This video
Message 6 of 23
Overriding the pattern helps a lot 😄
Message 7 of 23
A_MAQ
Great !
Your welcome
Message 8 of 23
chauh
Why not just use worksharing display? As long as the link is on a separate workset it should be easy.
Message 9 of 23
Override patterns are greyed out for the required element categories? i can't able to color the elements either by overriding the lines and cut lines color. Any suggestions?
Message 10 of 23
mlhier
I am trying to color a linked model black in ceiling plan. I've tried overriding the model in visibility graphics and applying a filter to the workset its in. Neither of those things worked.
Does anyone have an idea of what else I can try?
Message 11 of 23
JLSMART
I am following the same procedure. I can change the Line Pattern but changing the Line Weight or Line Color has not effect. I have a plumbing model linked to a structural model and all the objects are system families (pipe, pipe fittings).
Message 12 of 23
Jesse.Frome
@Anonymous
Having the same problem. Bump.
Message 13 of 23
jfoster4913
same, another bump
Message 14 of 23
henrik_pregler
Observer
Observer
Same problem. Another bump.
Message 15 of 23
jdumorne
Observer
Observer
Great!
Message 16 of 23
jf_martinezZ9LRT
Community Visitor
Community Visitor
great
Message 17 of 23
mariebtrnDBER5
Community Visitor
Community Visitor
In this case you need to use filters to change the colors of those categories. (Hoping that you do not use the same family categories as the MEP model in your own model) Let me know if that works.
Message 18 of 23
robert.wadeT49WY
BUMP
Message 19 of 23
EDunbarCPL
Same issue 😞
Message 20 of 23
projectfire_nmc
THAT is a brilliant function!  One I could've used daily through my Revit journey to date and one I'll be using daily from now.  Thank you A_MAC for that share...  Still valid and valuable 7 years on...
The more I learn, the more I realise I don't know.  Accurate for life as well as Revit.
