We need to dimension reinforcement C-bars by their center plane (which is perpendicular to rebar and they are distributed on the same plane - side by side as shown below) and it seems like revit can't "see" the reference plane that is in rebar shape family (I tried to put additional reference line there but with no visible result in the model after reloading the family). We "handle" this by adding short lines in the model views (copy or array them) but it is pain in the... to do so on every drawing (not to mention we have to remember to move these lines when we move the bars).
Question: Is there a way to make Revit see the center of C-bars while dimensioning it?
Thanks for help.
You are correct the reference plane will now show up in your model once the family is loaded, but you should still be able to snap your dimension to it. Are you able to snap to it? You may want to try naming it.
If you are looking for something that will physically show up in your model you could put in a centre line in the family and have it show up in the model.
Edit the family, select the center Reference Plane and set [Is Reference] to Center (Left/Right).
Yes, it is a rebar. I attach the family (it is typical revit rebar shape family - I didn't mess around with it).
