Cant Open IFC file in Revit 2016
I am trying to open an IFC file in RVT16. The file was originally exported from Tekla to IFC
The reason I want to open in Revit is so I can then link into another Revit project because If I link the IFC into the Revit project then Revit runs extremely slowly
Does anybody have any solution?
ennujozlagam
@Anonymous hello, check it HERE and see if helps. thanks
Thanks, I tried that but I already have the correct templates mapped
I think the answer is to link the structural IFC (fron tekla) to a Revit model as an attachment and then link into the MEP Revit model
ennujozlagam
@Anonymous hello, that could be the best soultion for your issue. Some explanation HERE. thanks
