Cant Edit Rebar Constraint, ERROR Warning
Hello, this is so frustrating that i cant give a spesific offside to my rebar
i use the edit constraint tool but it give me a warning
" The current rebar component has no constraint. You can apply a new constraint by selecting a valid target.
Rebar components are the geometrical references that define the bar set. For example, the shape segments or the host surface. "
what should i do ? like i want to give a 20 mm rebar from the side of beam but this tool wont work
ovidiu_paunescu
Hello @Anonymous
Like I mentioned in https://forums.autodesk.com/t5/revit-structure-forum/rebar-constraints/td-p/8409278, the faces resulting from the beam cut by the column cannot be currently selected as constraints.
You can click the side face of the column as a constraint target for the selected handle. The offset will have a positive value, because the bar is positioned outside the column face (negative offset is towards the inside of the element)
See the image below
Ovidiu Paunescu, M.Sc. Str. Eng.
Sr. Product Owner | Autodesk Revit
thank you !
tomasz.fudala
