cannot solve bar shape
BJX916_XUANWU115
BJX916_XUANWU115
Sometimes when editing the dimension of a bar via properties palette, a ‘cannot solve bar shape’ dialogue pops up, but the bar can be edited the dimension by dragging the handles, and sometimes the bar moves or changes dimensions automatically even the bar is locked.
Why do these happen and how to solve these issues?
ovidiu_paunescu
@BJX916_XUANWU115
When you drag the handles you can only drag in a certain range. For example you can't drag one leg of a U-shaped bar over the other, as the middle segment would have a 0 or negative length.
In the properties, you can enter any value. For the same U shape, if you enter a value for the middle segment length that means the fillets at the ends of that segment don't fit, you will probably get that error.
Ovidiu Paunescu, M.Sc. Str. Eng.
Sr. Product Owner | Autodesk Revit
BJX916_XUANWU115
Thank you for your reply, that helps me to understand the issue
