Cannot select beam in 2d view but can select in 3D view
Message 1 of 8
I am new to revit.
I cannot select beam in 2d view but can select in 3d view.
In 2d view, the beam colour is light gray and unselectable.revit 3.PNGrevit pro 1.PNGrevit pro 2.PNG
Here are the screenshots
Replies (7)
Message 2 of 8
Sahay_R
Make sure all of these boxes are checked
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 3 of 8
Thanks a lot,Here is another problem -- cannot selectable (tag system)system or framing in beam system.
Message 4 of 8
Sahay_R
Are you trying to tag or select elements in the beam system? Little confused here....
Rina Sahay
Message 5 of 8
serhatergindogan
I HAD THE SAME PROBLEM,THANKS ALOT
Message 6 of 8
Thank you so much
Message 7 of 8
AMadariaga100
THANK YOU! I know this is an old post but your response finally ended my growing headache I was having over this.  It was really driving  me nuts. All I wanted was to change the angle of my beam system to 45 degrees to create roof rafters which was a 2 second task but could NOT do it because I could not select them. Now I can. so thanks!
Message 8 of 8
AMadariaga100
sorry that was supposed to be a reply to Sahay_R . Not sure why it didn't tag her since I clicked reply directly underneath her suggested solution.
