Cannot perform save this document command because background calculations are in progress/
daniel7FDRJ
Message 1 of 83
daniel7FDRJ
Randomly cannot save my project. Not sure where this should go in the forums but I work mainly on structures so I figured here will do.
This is the second time I'm getting this error today and I've had work colleagues get similar errors and no one seems to know why or how to fix it?
As you can see from the image there are no background calculations running. They're also all turned off where possible. I have no idea how to get around this issue.
Replies (82)
Message 81 of 83
dcarmonagarcia
THANK YOU, I GUESS THE OPEN NEW FILE WORK FOR ME
Message 82 of 83
craig_bullLSEXH
Observer
Observer
Had this issue a while back, not sure why it happens but if you open up a project and save it (i keep a template handy on desktop) then go back to the problem project the calculations stop and you can save the file.
Message 83 of 83
gabriel.almeida65
Observer
Observer
It happens whith me all the time when I'm working with steel conections, plates, bolts, etc. Recently I just realise if I undo and redo the action that cause this, it works fine. Worth the try.
