Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Can you remove .00 from bolt tag?
2 REPLIES 2
djn9SY84
161 Views, 2 Replies
djn9SY84
Im trying to create a bolt tag.
i want it to look like the red text.
how do i remove ".00 mm" from the tag?
2 REPLIES 2
Tom_Kunsman
in reply to: djn9SY84
Tom_Kunsman
I don't use bolt tags, but it looks like if you modify the Units in the tag family, that should fix it. Will need to select the label to modify the units for that label.
hmunsell
hmunsell
unfortunatly, the Diameter parameter dose not allow you to edit its settings
you can look in the Units (UN) settings and set the discipline to Structural, maybe Common, and see if there is any category that might control that.
Howard Munsell
Howard Munsell
