Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Cant contour cut custom column
2 REPLIES 2
besMZY6P
147 Views, 2 Replies
Hi Guys
I can't contour cut my custom column. I get the warning below.
can anyone help ?
[ The subject line of this post has been edited for clarity by @handjonathan Original: Can,t co]
2 REPLIES 2
jay_colcombe
in reply to: besMZY6P
Connection are defined in Fine Detail and sometimes if there is a different Level of Detail between the 2 connection elements this error will occur.
Here is a link for a more detailed explanation and workarounds
Warning: "The shapes for medium and fine detail levels of connected element are inconsistent" while ...
Jay Colcombe
Autodesk Certified Instructor
handjonathan
Hi @besMZY6P
Thanks a lot for posting your question to the forums!   Has the solution suggested by @jay_colcombe helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
