I'm making reinforcement on Revit, and the time-consuming obstacle is to tidy up the intersecting top-bottom bars.
I use the rebar sketch tool to create rebars and I need to constraint one by one so the rebars do not overlap.
Can Revit be set to know and fix it automatically?
* Note: The reason I use the rebar tool instead of the Area tool is that I try to model the reinforcement just like the construction ie the maximum length of the reinforcement on the market (12 meters), lap splice, and hook.
Thank you.
