Can Revit know and automatically move intersecting rebar?
ReginaPA97
ReginaPA97
I'm making reinforcement on Revit, and the time-consuming obstacle is to tidy up the intersecting top-bottom bars.
I use the rebar sketch tool to create rebars and I need to constraint one by one so the rebars do not overlap.
Can Revit be set to know and fix it automatically?
* Note: The reason I use the rebar tool instead of the Area tool is that I try to model the reinforcement just like the construction ie the maximum length of the reinforcement on the market (12 meters), lap splice, and hook.
Thank you.
hmunsell
Unfortunately i don't believe so...
You can write a Dynamo script to pull the elevation of the rebar in selected areas. then maybe move items that are at the same elevation by a specific increment?
Howard Munsell
DavidDillonJr
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2021/EN...
@ReginaPA97 Yes, you have to set-up rebar constraints, the link above covers it.Capture.JPG
I also suggest you sign up for Autodesk Design Academy. Take this course Cert Prep for Autodesk Certified Professional: Revit for Structural Design.
Watch lesson 2 - video 18 - Working With Reinforcement tools Part 5.
David Dillon
ReginaPA97
I never use Dynamo before, I will find out.
Thank you for your information.
ReginaPA97
Amazing, thank you for your information. I never knew there's a web like that. I will use it immediately.
