Can rebar form a different angle with beam in Revit ?
I want to adjust the angle between rebar and beam like the inclined stirrups in the attached image.
So far I can not find any properties to change this angle, the rebar seems to always form a 90 degree with the selected beam.
Does anyone have any ideas to make this happen in Revit ?
Ahmed_M_Heteba
hi you can do it using the steps belwo :
1 . draw the beam and sections like pic 1
2. go to longitudinal section and draw reference plane an name it like pic 2
3. go to cross section and set work plane to the inclined refrence plane you draw and draw your stirups and adjust the constraint like pic 3
Ahmed Heteba, PMP, bsi, B.Sc, AEE, ACI, ACP
Senior BIM Manager @ EllisDon
ovidiu_paunescu
Hi @Anonymous
You can use @Ahmed_M_Heteba , but don't copy the stirrup that you have sketched.
Instead, select the stirrup, click the varying rebar set button and then change the layout > Max spacing or some other option.
Ovidiu Paunescu, M.Sc. Str. Eng.
Sr. Product Owner | Autodesk Revit
Ahmed_M_Heteba
yes i forgot the step of varying rebar
also make the stirrups maximum spacing or no with spacing
Ahmed_M_Heteba
did it work with you?
