C-Purlin Family "Unknown shape of connected element"
Tinman1975
Message 1 of 17
Tinman1975
@_Vijay
Attached in 2020 version
Replies (16)
Message 2 of 17
_Vijay
You expecting like attached. .let me know your comments..
Vijayakumar
Head of BIM
Did you find this post helpful? Feel free to like this post.
Message 3 of 17
Tinman1975
@_Vijay  more like this image
Message 4 of 17
Tinman1975
Family attached
Message 5 of 17
catalin_lang
This family has an issue: "The shapes for medium and fine detail levels of connected element are inconsistent"
see attached picture... those flange's lines should overlap.
We know about it and it will be solved soon.
Till then, you can:
1. Adjust M-C-Channel-Profile-Medium shape so it match the Fine shape
2. Use another family
catalin.lang
Message 6 of 17
Tinman1975
thanks @catalin_lang are there any C-Pulins available for download that work ??
Message 7 of 17
catalin_lang
I see your families are US metric... the "old" ones... you can try the "new" ones from AISC 14.1 folder.
(I'm also attaching it for 2020 release file format)
catalin.lang
Message 8 of 17
Tinman1975
thanks @catalin_lang, i'm looking to use the Australian Light Gage Steel Pulins.
Message 9 of 17
Tinman1975
@catalin_lang do i attempt to change the family you have sent to the C- Purlin Range attached
Message 10 of 17
catalin_lang
@Tinman1975 , I was looking to @_Vijay file. Sorry!
Back to your case...
Your family don`t have Section shape defined
- open your family
- go to Family Category and Parameters dialog
- set the Section Shape to C Profile with Lips
(see clips pic)
This is not enough... you need to also define its geometrical parameters for each type.
(see clips2 pic)
There are families that might be already defined to work with steel fabrication workflow that suites your needs, but I need to search for them.
catalin.lang
Message 11 of 17
_Vijay
I have taken Autodesk Library (C:\ProgramData\Autodesk\RVT 2020).
- open your family
(see clips pic)
(see clips2 pic)
you mean somewhere I need to look?
Vijayakumar
Head of BIM
Message 12 of 17
Tinman1975
Wow...  that is so high above my knowledge Level... @catalin_lang @_Vijay @hmunsell
but will give it a go !!!  Thanks Mate !!!!
Message 13 of 17
Tinman1975
@catalin_lang  @catalin_lang
This is way over my head.... if anyone can assit with creating this family for me that would be greatly appreciated, and i will owe someone a virtual Beer !!
Message 14 of 17
Tinman1975
Can Anyone help ??
Message 15 of 17
Tinman1975
@hmunsell  any assistance would be great  ??
Message 16 of 17
_Vijay
Try with attached let me know your comments...
Vijayakumar
Head of BIM
Message 17 of 17
Tinman1975
@_Vijay  thank you... the solution attached give me this "The shape for medium detail level of connected element contains rounding" warning when applying a structural connection
Warning id: 2685572
