Building Section mark not showing in the structure view
REDO10
REDO10
Hi All,
Hi @ovidiu_paunescu
In my project I can not display the building section mark that have an architecture discipline in the structure view, although I checked all the visibility parameters and view scale that is compatible between architecture view and structure view (see picture bellow)
I need to display this building section mark in the same placement in the structure view to indicate rebars detail in that place, so how do I do that?
finally I noticed that REVIT gave another number to my building section in the structure view so normally it’s the same number I have to display in the sheet, how do I fix that?
Thanks.
L.Maas
Probably the section view itself is not set to Structural discipline. If you set that section to structural I expect it will show.
Usually the number is the Detail Number.
The section automatically gets assigned a sequential number when placed on a sheet. You can modify it to another number/text.
Louis
Please mention Revit version, especially when uploading Revit files.
Change the section view from Architectural to Coordination discipline.
REDO10
@L.Maas
@ToanDN
Indeed, the section view is architectural and not structural and that’s what I’m trying to explain!!!
I want my architectural section to be displayed at the same time in my structural view because it cut in the same place and I want to display rebars detail in that specific placement.
I made two sections in the same place (one architectural and the other structural) but Revit gives me two different details numbers  while I want it to be the same number in the sheet!!
Thanks.
REDO10
Thanks ToanDN for this tip...my problem is solved now
