Building Envelope design
Would anyone suggest which Auto-desk product is the best for designing the building envelope?
I am currently using AutoCAD LT 2019 to draw 2D and Iso for designing the building envelope.
I would like to update the program to show 3D assembly on the document along with 2D.
considering to purchase one of the Auto-desk product and like to have any advice.
Among Autodesk products Revit is the obvious choice.
Thank you for your prompt response ToanDN 🙂
Will Revit work well with wood frame structure & sloped roof (Design the wood framed town-house building) ?
Yes if you are doing design and construction documents.  However, if you are looking into model the actual stud framing then Revit itself does not do it without a lot of work.  For such, you would need to buy some 3rd party wood framing add-in for Revit.
Thank you for your advise.
Yes, I would like to show/draw the actual stud frame and cladding etc and present in 3D and 2D.
Would you recommend an add-in product that would work well with Revit ? I applicate your recommendation and will lean about it.
Thank you ToanDN !
