Beams not showing Course line when edit family
info
info
HI
I opened Revit from using Revit lt,
When editing beam families and I can't see or turn on the Line which is shown the beam in course view (in edit family)
but I can see it in model.
I want to alter the line style
L.Maas
Sometimes things are only added when loaded into the project and not in the family itself.
However you can manipulate the lines in the project (or project template)
For example this beam has "Structural Usage" = "Other"
When I go to Visibility Graphics Overides I can override the linetype for that sub-category
Louis
Please mention Revit version, especially when uploading Revit files.
PavelAnd
Hi @info. @L.Maas is right, but also don't forget use "pveriew visibilyty" mode in family.
Best regards, Pavel Plotitsyn.
