Beams dont follow grid movement
walidinJKACC
walidinJKACC
When i move the grid to make it wider, why beams dont follow grid/column?
They occur on every level.
Note:
I have checked analitycal view and they look OK connected to each other.
catalin_lang
Can you share a part of your model? Grids 6 and 7, with the 4 "vertical" grids visible in your pictures? 1-2 levels should be enough.
I cannot tell from the pictures.
Thank you
catalin.lang
mauricio_mssf
Depending on the form that created these beams, they may not be linked to the grid, or due to some error they were disconnected, to resolve, go in the floor plan, align he beam to the Grid and lock to create / return this restriction.
If any element of the model is not following any constrain you wanna to, you need to imput it.
If the answer solves your problem, click Accept as Solution this helps other users to quickly find an answer and let a like if you liked it
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
 Mauricio Santos Filho Arquiteto | BIM Manager
walidinJKACC
@catalin_lang here I share the model
walidinJKACC
As default beam doesnt follow the grid (not constrain to the grid ) but follow the column (contrain to column). When grid moved, the column  should follow the grid and beam automatically follow them.
